Support Forums › Forums › FIR Designer M Support › Convert EV IRIS FIR to Powersoft? › Reply To: Convert EV IRIS FIR to Powersoft?
>> My backup plan is to use the latest IIR presets, which I have used for years and
>> like the sound, feed them into FIR Designer-M, and create new, similar, but phase-linear versions.
You can recreate the presets from electrical measurements, however I would NOT convert each channel to linear-phase. The phase differences between channels in the multi-way are part of the preset and are inherent in making the preset work. If you change these relationships, you could dramatically alter the system’s response and directivity in and around the crossover region.
As for making the combined acoustic response linear-phase, in addition to electrical measurements of the preset, you would need some reliable or meaningful acoustic measurements.
