Support Forums › Forums › FIR Designer M Support › SMAART .trf files not loading properly › Reply To: SMAART .trf files not loading properly
22 May 2025 at 8:24 am
#1040
Files received, thanks. The magnitude, phase and coherence of the file is loading correctly, so you can continue through the FIR Designer M workflow as normal. The issue appears to be in the sample rate conversion from the file’s 44.1 kHz sample rate to the FIR Designer M channel sample rate – e.g. 48 kHz – and only affects frequencies near the half Nyquist frequency (22.05 kHz to 24 kHz). Note: if you set the channel sample rate to 44.1 kHz, the impulse response is clean.
We’re looking into this now.
