Support Forums › Forums › FIR Designer M Support › SMAART .trf files not loading properly › Reply To: SMAART .trf files not loading properly
22 May 2025 at 9:51 am
#1042
Ok, we’ve found the problem and it has nothing to do with the sample rate. We need to chase this issue with Rational Acoustics as it’s something inherent in the TRF measurement at very high frequencies. Like I said above, below 20 kHz, everything is ok so you can continue with the filter design process.
