Support Forums › Forums › FIR Designer M Support › Using SpeakerMeasure for FIR Designer M › Reply To: Using SpeakerMeasure for FIR Designer M
    30 May 2025 at 9:54 am #1049
    I’m blessed to have received original speaker response .txt files (LF MB HF) for the EV XLVS and XVLT from the retired Electro-Voice chief engineer who led their XLine line array speaker system project 25-30 years ago. He sent me .txt with Magnitude only several weeks ago, using which I built presets successfully.
    This morning, he (found) and sent the more complete files which contain BOTH Magnitude and Phase. However, when I worked through the tabs building new presets today, I noticed anything I did with FIR Phase or Auto Phase failed the output Export files. Could it be as simple as the column / starting value of the .txt files? Please provide a better / more thorough description of the proper required Import file format and syntax, etc.
    I am able to send an example .txt file to you if that helps – I don’t see how to attach it to do this request…
    Thank you for your continued prompt personal attention and assistance.
    RBT
