Support Forums › Forums › FIR Designer Support › Single channel › Reply To: Single channel
Our single-channel products are aimed more at EQ’ing full speakers and system tuning, but can be used for multi-way loudspeaker design – by using one channel project per driver. However it’s not possible to see the combined, summed response of all drivers. (FIR Designer allows multiple program windows to be be displayed so it’s possible to look at, and work on, all channel projects simultaneously.)
FIR Designer M is aimed at multi-way loudspeaker design and shows the combined response at every stage of the workflow. It also has tools for viewing off-axis responses with the multi-way processing.
So, yes, if your focus is designing processing (including crossovers) for multi-way loudspeakers, FIR Designer M is the best product.
