Support Forums › Forums › FIR Designer M Support › Auto IIR target doesn’t account system target › Reply To: Auto IIR target doesn’t account system target
    24 July 2025 at 8:56 pm #1090
    Thank you. In addition to fixing AutoIIR, please consider adding a checkbox labeled “Ignore system target” in the Channel Target tab. I believe this could be useful in two scenarios:
    1) When a channel should follow a combined target of system + channel – for example, an HF driver that blends a flat response with that of a Mid or Midbass channel.
    2) When the system target is only met through the combined response of channels that share a wide overlapping band, such as Sub and Midbass. In this case, the Sub may have a gain boost, and it could be helpful to disable the system target for these individual channels. Therefore I need to avoid huge bending of slopes for those channels because it reduces headroom, I need use channel gain and overlapping to met this system target.
    I’m open to any advice on how to implement such designs using existing functionality or your suggested alternatives, if the checkbox isn’t the best approach.
    System target example
    PS: thank you for fast fix, I was not expecting it to be done before I add this message about checkbox, so sorry for revisiting this issue again
    • This reply was modified 1 year, 3 months ago by YKH.
