Support Forums Forums FIR Designer M Support Copying channels Reply To: Copying channels
    3 August 2025 at 10:08 pm #1133
    In the current version of “FIR Designer M” there is not a way to copy all DSP settings from one channel to another in one go. But we have added this to the TODO list.
    Many of the tabs in the workflow have copy and paste functions, so you could copy most of the settings between channels. However Auto Mag and Auto Phase functions depend on the Import tab measurement, so you need to load the same measurement on both channels (and make sure settings of every workflow tab are the same) to ensure the DSP is the same across multiple channels when using AuditionDSP.
    AuditionDSP in “FIR Designer M” runs DSP for as many channels as FIR Designer M is configured for.
    In “FIR Designer” (which is only one channel of DSP), AuditionDSP has an option to run the DSP in stereo.
