Support Forums › Forums › FIR Designer Support › UI Improvement › Reply To: UI Improvement
    11 July 2020 at 11:37 pm #198
    Can you be so kind as to consider adding the graph color option in the Import tab for both the magnitude and the impulse response graphs?
    I was doing a basic comparison of a power-smoothed graph vs an unsmoothed one and could only change the color of the processed graph and not the original one if the “Original (before smoothing)” option is turned on. The “Original (before smoothing)” option for the Impulse Response would be nice as well since it is also affected by the smoothing operation. It will allow one to be a bit more granular in doing a comparative analysis of the smoothing operation.
    Graph
    • This reply was modified 6 years, 4 months ago by EA Support.
