Support Forums › Forums › FIR Creator Support › 360 degrees phase jump › Reply To: 360 degrees phase jump
6 August 2020 at 10:08 pm
#256
Hi Kohno,
Looking at the images in your PPT file, the measurement has 3×360 degree phase rotation coming into the Auto Phase tab. (This is quite unusual. Maybe you have a 12th order crossover filter?) If you’re trying to unwrap this phase, it’s better to address this manually on the Phase Adjust tab with 3 x 2nd order all-pass filters set for maximum phase. (The Auto Mag tab can’t always follow 360 degree phase rotations – particularly ones as steep as this – depending on the amount of smoothing in use.) And keep in mind a FIR filter with 3×360 degree phase rotation will be quite long.
