Support Forums › Forums › FIR Creator Support › 360 degrees phase jump › Reply To: 360 degrees phase jump
Hello EA support,
Thank you for your advice. This loudspeaker is back loaded horn type. I use up all 8 x 2nd order all-pass filters (maximum phase) for phase rotations in lower frequencies, so I cannot do it unless I upgrade to FIR Designer. FIR has 6100 taps.
I have 3 questions.
1. That REW shows 360 degrees phase jump means Auto Phase tab corrects 2 x 360 but cannot remaining 360, therefore it is appeared in REW measurement, correct?
2. You mentioned “depending on the amount of smoothing in use”. I use 1/6 Oct smooth. Which one (1/3 or 1/12) will be better for the case?
3. Auto Phase tab and Export tabs show that phase is corrected to linear. Why it does not show 360 degree rotation in these tabs as REW says if it cannot correct?
Kohno
