Support Forums › Forums › FIR Creator Support › 360 degrees phase jump › Reply To: 360 degrees phase jump
    7 August 2020 at 3:14 pm #259
    Thank you for your advice. Based on your input I took several measurements and it was appeared that the rotation was happened sometime and not happened sometimes. This loudspeaker has 300 cm long horn so it is not usual as you pointed. Anyway thanks again!
    Kohno
