Support Forums Forums FIR Creator EX Support FIR Creator EX with Qsys Reply To: FIR Creator EX with Qsys
    31 October 2020 at 9:40 pm #274
    Hi Weiguo,
    The IIR “Text file (Annotated TF)” export from all our products contains parameter settings and raw biquad coefficients (at the FIR Creator sample rate).
    Is this the QSYS IIR block you are using?
    https://q-syshelp.qsc.com/#Schematic_Library/filter_IIR.htm?Highlight=IIR
    We can implement a Qsys specific CSV export in a future update. In the meantime, you can make a CSV by taking the FIR Creator TXT file and copying the coefficients into a CSV file. For example
    IIR Mode: General
    Sampling Rate: 48000 Hz
    HPF_BUTTERWORTH, 100.000 Hz, Order 2
    b0:0.9907866979404248 b1:-1.9815733958808497 b2:0.9907866979404248
    a0:1.0000000000000000 a1:-1.9814885091445689 a2:0.9816582826171297
    becomes
    0.9907866979404248, -1.9815733958808497, 0.9907866979404248, 1.0000000000000000, -1.9814885091445689, 0.9816582826171297
    • This reply was modified 5 years, 4 months ago by EA Support.
