Support Forums › Forums › FIR Creator Support › Binary File 32bit Float wrong result on MiniDSP 2x4HD › Reply To: Binary File 32bit Float wrong result on MiniDSP 2x4HD
18 February 2022 at 6:15 am
#421
>> I use FIR Filters for Hifi Equipment. Do you have an good idea for me which
>> FIR Equalizer works fine to build an active crossover with more than 1024 taps
>> for each channel?. Balanced Outputs desired if possible. Mini DSP2x4HD is fine,
>> but I would wish in first order more channels and more taps if possible. Also
>> better sound quality should be fine..
Sorry, we don’t have the time to keep up-to-date on the latest processors. MiniDSP have a few multi-channel products that may run longer filters, and a number of their products support balanced IO.
