Support Forums › Forums › FIR Creator Support › Unable to import target from REW › Reply To: Unable to import target from REW
    28 February 2022 at 6:50 am #447
    Hi liveNathan,
    Take a look at
    Loudspeaker Measurement Import File Formats
    The file starts with:
    * Measurement data measured by REW V5.20.5
    * Source: EQ window target shape
    * Format:
    * Dated: Feb 27, 2022 11:39:39 AM
    * REW Settings:
    * C-weighting compensation: Off
    * Target level: 75.0 dB
    * Note:
    * Measurement: Target Main Native
    * Smoothing: 1/48 octave
    * Frequency Step: 96 ppo
    * Start Frequency: 2.5 Hz
    * Freq(Hz), dBFS(dBFS)
    2.500000, -125.155
    2.518116, -124.904
    2.536363, -124.653
    2.554743, -124.402
    2.573256, -124.151
    2.591902, -123.900
    2.610684, -123.649
    2.629602, -123.399
    2.648658, -123.148
    2.667851, -122.897
    2.687183, -122.646
    2.706656, -122.395
    2.726269, -122.144
    It’s a 2 column file with Freq & Magnitude but “FIR Creator” requires 3 or 4 column for Freq|Mag|Phase|Coherence. Since there are so many different ways TXT and CSV files can be created, we’ve had to put some rules around how we import files. We do look for a few special cases, and for REW, we currently look for the starting line
    * Impulse Response data saved by REW
    We’ll look at adding something for this file’s header also.
    In the meantime I suggest copying this into Excel, adding a 3rd column of 0’s, and saving as a 3 column txt file.
    Alternatively, if your intended target response is something simple, use “FIR Creator” in “Direct Design” mode, make your target response, export as a FIR Designer Target File (FDT) and import this on the Target tab.
