Support Forums Forums FIR Designer M Support Save IRR coefficients to File – CSV for QSC Qsys IIR is not working. Reply To: Save IRR coefficients to File – CSV for QSC Qsys IIR is not working.
    25 June 2022 at 7:57 am #490
    Thanks, we’ll add a comma to line ends.
    I’ve been testing here also. For me Q-SYS Designer (9.4.2) is only loading the first line.
    Can you confirm that Q-SYS Designer is loading all four lines for you? If the QSYS Designer Custom IIR Block doesn’t look like FIR Designer, and if it has no more than ~180 of phase change across the plot, then it’s only loading the 1st line.
    Their support page
    https://q-syshelp.qsc.com/Index.htm#Schematic_Library/filter_IIR.htm
    shows that the block should be capable of loading multiple lines.
    EDIT
    I realised I needed to set the “Section Count” to the number of rows. With this set, all the lines of the CSV load correctly for me here.
    • This reply was modified 3 years, 8 months ago by EA Support.
