Support Forums › Forums › FIR Designer M Support › Export Issue › Reply To: Export Issue
    16 October 2025 at 12:14 pm #501158
    Thanks Olli.
    We have replicated the problem. What’s happening is that the first channel to be saved is the current channel you have selected in the ‘Channels’ ‘Edit Channel” drop down. For example, if ‘Edit channel’ is set to channel 3, the first channel FIR file to be saved actually contains data for channel 3 instead of channel 1. The other files, for channels 2 to 6, are correct.
    We will have a fix in the next ‘FIR Designer M’ release. In the meantime, set ‘Edit Channel” to 1 before pressing “Save FIR’s” or “Save FIR’s + Summary”.
