Support Forums › Forums › FIR Designer Support › Hypex FIR filter txt file 1500 taps › Reply To: Hypex FIR filter txt file 1500 taps
Thanks, Works very good. I created the filters so what is left is to test the Export to Hypex. Please confirm as Hypex only take 1500taps that if I create a Low Pass filter and a High Pass filter under Magnitute Filer Design and both set to ON and choose under EXPORT – Filter Sample Rate 1500 the TXT file coöumn, decimal) will corespond to 1500 taps for one hypex channel. Also confirm Filter delay samples 256 (choosen by the program and not to be changed) , and the Window Kaiser-Bessle Alpha 6 is ok ? DC compensation to be set to ON ? Also Save as FIR only and DTP not to be changed. If above confirmed I am ready to do this in the real FIR Designer.
