Support Forums › Forums › FIR Designer Support › Hypex FIR filter txt file 1500 taps › Reply To: Hypex FIR filter txt file 1500 taps
Setup
– Sample rate: 93.75 kHz
– Filter length: 1500 samples
– Filter delay: 256 samples
– Window: Cosine Tapered. (Note: the Kaiser-Bessel alpha 6 caused more mag and phase deviation for your filter choices.)
– Magnitude Adjust tab
— Min phase, HPF LR, 200 Hz, order 4
— Min phase, LPF LR, 5000 Hz, order 4
Copy the following and pasted into a TXT file.
0.0000000000944925
0.0000000008482109
0.0000000023438032
0.0000000045577274
0.0000000074551338
0.0000000109903867
0.0000000151077853
0.0000000197424448
0.0000000248212188
0.0000000302639237
0.0000000359845651
0.0000000418926711
0.0000000478948975
0.0000000538964606
0.0000000598026879
0.0000000655206401
0.0000000709603932
0.0000000760364546
0.0000000806691075
0.0000000847854418
0.0000000883205904
0.0000000912187725
0.0000000934340695
0.0000000949313675
0.0000000956869389
0.0000000957832594
0.0000000957851317
0.0000000957871127
0.0000000957891588
0.0000000957912198
0.0000000957931250
0.0000000957946026
0.0000000957954243
0.0000000957953432
0.0000000957941916
0.0000000957920082
0.0000000957889545
0.0000000957853596
0.0000000957816862
0.0000000957783384
0.0000000957756612
0.0000000957738931
0.0000000957730726
0.0000000957731412
0.0000000957739482
0.0000000957752464
0.0000000957768457
0.0000000957786201
0.0000000957805019
0.0000000957825379
0.0000000957847630
0.0000000957871364
0.0000000957895745
0.0000000957918777
0.0000000957937800
0.0000000957950355
0.0000000957953936
0.0000000957947009
0.0000000957929859
0.0000000957904176
0.0000000957873377
0.0000000957841888
0.0000000957813597
0.0000000957791716
0.0000000957778198
0.0000000957773260
0.0000000957776187
0.0000000957785279
0.0000000957798110
0.0000000957812793
0.0000000957828076
0.0000000957843506
0.0000000957859625
0.0000000957876758
0.0000000957894539
0.0000000957912027
0.0000000957927215
0.0000000957937637
0.0000000957940967
0.0000000957934941
0.0000000957918376
0.0000000957891811
0.0000000957857298
0.0000000957818600
0.0000000957780248
0.0000000957746200
0.0000000957719628
0.0000000957702333
0.0000000957694530
0.0000000957695508
0.0000000957703523
0.0000000957716238
0.0000000957731822
0.0000000957749075
0.0000000957767686
0.0000000957788187
0.0000000957810760
0.0000000957834888
0.0000000957859360
0.0000000957881969
0.0000000957900173
0.0000000957911528
0.0000000957913726
0.0000000957905619
0.0000000957887728
0.0000000957862165
0.0000000957832709
0.0000000957803713
0.0000000957778906
0.0000000957761162
0.0000000957751934
0.0000000957751238
0.0000000957758190
0.0000000957770892
0.0000000957786992
0.0000000957804671
0.0000000957822795
0.0000000957841214
0.0000000957860501
0.0000000957880808
0.0000000957901595
0.0000000957921583
0.0000000957938591
0.0000000957950237
0.0000000957954218
0.0000000957948467
0.0000000957932150
0.0000000957906086
0.0000000957872748
0.0000000957836198
0.0000000957800884
0.0000000957770566
0.0000000957748061
0.0000000957734724
0.0000000957730566
0.0000000957734691
0.0000000957745181
0.0000000957759759
0.0000000957776679
0.0000000957794904
0.0000000957814406
0.0000000957835721
0.0000000957858860
0.0000000957883120
0.0000000957906991
0.0000000957928143
0.0000000957944118
0.0000000957952514
0.0000000957951244
0.0000000957939516
0.0000000957918184
0.0000000957889798
0.0000000957858412
0.0000000957828293
0.0000000957802977
0.0000000957784995
0.0000000957775418
0.0000000957774084
0.0000000957779936
0.0000000957790934
0.0000000957804811
0.0000000957819870
0.0000000957835193
0.0000000957850904
0.0000000957867574
0.0000000957885195
0.0000000957903048
0.0000000957919593
0.0000000957932581
0.0000000957939710
0.0000000957938737
0.0000000957927833
0.0000000957906532
0.0000000957876016
0.0000000957839195
0.0000000957800366
0.0000000957763870
0.0000000957733257
0.0000000957710996
0.0000000957698085
0.0000000957694358
0.0000000957698721
0.0000000957709118
0.0000000957723351
0.0000000957739800
0.0000000957757651
0.0000000957777110
0.0000000957798664
0.0000000957822144
0.0000000957846642
0.0000000957870397
0.0000000957891016
0.0000000957906093
0.0000000957913268
0.0000000957910688
0.0000000957897913
0.0000000957876160
0.0000000957848393
0.0000000957818838
0.0000000957791616
0.0000000957770024
0.0000000957756232
0.0000000957750962
0.0000000957753860
0.0000000957763645
0.0000000957778138
0.0000000957795147
0.0000000957813105
0.0000000957831318
0.0000000957850107
0.0000000957869954
0.0000000957890654
0.0000000957911275
0.0000000957930039
0.0000000957944642
0.0000000957952818
0.0000000957952359
0.0000000957941681
0.0000000957920668
0.0000000957890876
0.0000000957855610
0.0000000957819290
0.0000000957786089
0.0000000957759309
0.0000000957741056
0.0000000957732001
0.0000000957731781
0.0000000957739067
0.0000000957751683
0.0000000957767522
0.0000000957785111
0.0000000957803877
0.0000000957824197
0.0000000957846453
0.0000000957870286
0.0000000957894587
0.0000000957917388
0.0000000957936270
0.0000000957948864
0.0000000957952868
0.0000000957946705
0.0000000957930316
0.0000000957905319
0.0000000957875077
0.0000000957843916
0.0000000957815795
0.0000000957793782
0.0000000957779706
0.0000000957774007
0.0000000957776150
0.0000000957784633
0.0000000957797200
0.0000000957811788
0.0000000957827010
0.0000000957842445
0.0000000957858575
0.0004996944813211
0.0035107221944940
0.0118673821681859
0.0265009087342906
0.0453012341027780
0.0646005480146380
0.0808801119686933
0.0916295809399096
0.0956187820138411
0.0928057040375981
0.0840559757090480
0.0707992468800185
0.0547031851062964
0.0374095031155317
0.0203494745763889
0.0046382318112636
-0.0089635865286883
-0.0200372419936268
-0.0284596672230707
-0.0343392459419244
-0.0379462171461797
-0.0396468191480906
-0.0398469220877420
-0.0389480176075651
-0.0373162044051284
-0.0352632543722986
-0.0330379045137943
-0.0308250858671746
-0.0287507458452744
-0.0268901215658507
-0.0252776712268269
-0.0239172825640033
-0.0227917892241682
-0.0218711964507747
-0.0211193240560173
-0.0204988087160911
-0.0199745707815855
-0.0195159510898830
-0.0190977721479812
-0.0187005880566896
-0.0183103706823195
-0.0179178463469937
-0.0175176561923804
-0.0171074707279060
-0.0166871492499013
-0.0162580004296311
-0.0158221726484049
-0.0153821818154245
-0.0149405699546328
-0.0144996788946242
-0.0140615188574211
-0.0136277105100515
-0.0131994800934781
-0.0127776897015246
-0.0123628879488985
-0.0119553696204916
-0.0115552360763703
-0.0111624509793026
-0.0107768882051021
-0.0103983705639696
-0.0100266992318776
-0.0096616746268385
-0.0093031099449930
-0.0089508387781549
-0.0086047182452404
-0.0082646289531138
-0.0079304729125091
-0.0076021703139077
-0.0072796558470694
-0.0069628750453737
-0.0066517809633546
-0.0063463313577096
-0.0060464864379522
-0.0057522071799190
-0.0054634541490847
-0.0051801867551937
-0.0049023628502225
-0.0046299385834233
-0.0043628684355733
-0.0041011053668069
-0.0038446010260806
-0.0035933059833647
-0.0033471699576313
-0.0031061420238130
-0.0028701707896177
-0.0026392045390495
-0.0024131913435142
-0.0021920791437128
-0.0019758158070319
-0.0017643491655805
-0.0015576270397242
-0.0013555972515882
-0.0011582076321516
-0.0009654060246731
-0.0007771402866545
-0.0005933582917883
-0.0004140079327571
-0.0002390371254736
-0.0000683938148458
0.0000979740180336
0.0002601183473357
0.0004180910928808
0.0005719441097263
0.0007217291771507
0.0008674979874233
0.0010093021345628
0.0011471931031652
0.0012812222574997
0.0014114408308718
0.0015378999152642
0.0016606504514010
0.0017797432191416
0.0018952288281534
0.0020071577089106
0.0021155801038991
0.0022205460590752
0.0023221054156807
0.0024203078022990
0.0025152026271803
0.0026068390708477
0.0026952660788572
0.0027805323548071
0.0028626863536044
0.0029417762748537
0.0030178500564375
0.0030909553682439
0.0031611396059853
0.0032284498852762
0.0032929330359396
0.0033546355964877
0.0034136038088719
0.0034698836133986
0.0035235206438024
0.0035745602225925
0.0036230473565434
0.0036690267323122
0.0037125427122380
0.0037536393302013
0.0037923602876408
0.0038287489498241
0.0038628483422509
0.0038947011472639
0.0039243497008613
0.0039518359895904
0.0039772016476519
0.0040004879541844
0.0040217358306059
0.0040409858381073
0.0040582781752233
0.0040736526754462
0.0040871488050635
0.0040988056611463
0.0041086619696604
0.0041167560838022
0.0041231259824235
0.0041278092685726
0.0041308431682561
0.0041322645292611
0.0041321098200618
0.0041304151288530
0.0041272161625738
0.0041225482460624
0.0041164463214020
0.0041089449473304
0.0041000782988236
0.0040898801668178
0.0040783839579540
0.0040656226945029
0.0040516290143963
0.0040364351712553
0.0040200730345402
0.0040025740897087
0.0039839694383778
0.0039642897986810
0.0039435655056999
0.0039218265119792
0.0038991023882330
0.0038754223240679
0.0038508151287956
0.0038253092324220
0.0037989326866175
0.0037717131657487
0.0037436779679895
0.0037148540163624
0.0036852678598987
0.0036549456749355
0.0036239132664116
0.0035921960693284
0.0035598191502870
0.0035268072090001
0.0034931845799740
0.0034589752342205
0.0034242027809210
0.0033888904692009
0.0033530611898433
0.0033167374769842
0.0032799415099881
0.0032426951153194
0.0032050197684808
0.0031669365961200
0.0031284663780830
0.0030896295495509
0.0030504462033173
0.0030109360919673
0.0029711186301203
0.0029310128967136
0.0028906376371556
0.0028500112656139
0.0028091518673835
0.0027680772011967
0.0027268047017149
0.0026853514820343
0.0026437343361266
0.0026019697414648
0.0025600738615933
0.0025180625486220
0.0024759513458459
0.0024337554902223
0.0023914899148289
0.0023491692515085
0.0023068078334126
0.0022644196976254
0.0022220185879552
0.0021796179575758
0.0021372309717898
0.0020948705108990
0.0020525491728766
0.0020102792761590
0.0019680728624346
0.0019259416992220
0.0018838972826627
0.0018419508403104
0.0018001133337946
0.0017583954617598
0.0017168076627079
0.0016753601177416
0.0016340627535864
0.0015929252453955
0.0015519570194823
0.0015111672562777
0.0014705648929543
0.0014301586261035
0.0013899569146726
0.0013499679825560
0.0013101998214223
0.0012706601937372
0.0012313566353611
0.0011922964585366
0.0011534867549008
0.0011149343979903
0.0010766460463148
0.0010386281461427
0.0010008869338358
0.0009634284391080
0.0009262584874450
0.0008893827027067
0.0008528065105296
0.0008165351403781
0.0007805736287913
0.0007449268222912
0.0007095993795296
0.0006745957747356
0.0006399202999144
0.0006055770674145
0.0005715700129443
0.0005379028976607
0.0005045793110263
0.0004716026735330
0.0004389762390463
0.0004067030977308
0.0003747861786680
0.0003432282523201
0.0003120319333520
0.0002811996830746
0.0002507338118656
0.0002206364818154
0.0001909097090510
0.0001615553661794
0.0001325751848869
0.0001039707582986
0.0000757435435129
0.0000478948641773
0.0000204259128340
-0.0000066622466009
-0.0000333686764350
-0.0000596925629939
-0.0000856332142802
-0.0001111900577340
-0.0001363626380872
-0.0001611506150501
-0.0001855537610769
-0.0002095719591388
-0.0002332052003563
-0.0002564535817669
-0.0002793173041182
-0.0003017966696150
-0.0003238920798341
-0.0003456040336343
-0.0003669331250421
-0.0003878800412716
-0.0004084455606803
-0.0004286305506886
-0.0004484359657661
-0.0004678628453224
-0.0004869123116193
-0.0005055855677959
-0.0005238838958681
-0.0005418086548159
-0.0005593612787605
-0.0005765432751033
-0.0005933562227473
-0.0006098017703590
-0.0006258816345570
-0.0006415975981306
-0.0006569515082222
-0.0006719452744498
-0.0006865808671196
-0.0007008603154692
-0.0007147857059308
-0.0007283591804908
-0.0007415829350496
-0.0007544592177987
-0.0007669903276819
-0.0007791786128285
-0.0007910264689673
-0.0008025363378451
-0.0008137107055809
-0.0008245521010554
-0.0008350630943858
-0.0008452462954260
-0.0008551043523380
-0.0008646399502109
-0.0008738558096781
-0.0008827546856012
-0.0008913393657889
-0.0008996126696795
-0.0009075774470117
-0.0009152365764440
-0.0009225929641453
-0.0009296495424568
-0.0009364092686068
-0.0009428751234624
-0.0009490501103330
-0.0009549372537760
-0.0009605395984345
-0.0009658602079391
-0.0009709021638103
-0.0009756685643334
-0.0009801625233958
-0.0009843871692793
-0.0009883456434903
-0.0009920410996754
-0.0009954767025931
-0.0009986556271295
-0.0010015810573345
-0.0010042561854725
-0.0010066842111323
-0.0010088683403794
-0.0010108117848885
-0.0010125177610211
-0.0010139894888436
-0.0010152301911316
-0.0010162430924428
-0.0010170314182672
-0.0010175983942143
-0.0010179472452089
-0.0010180811946934
-0.0010180034638644
-0.0010177172709739
-0.0010172258306540
-0.0010165323531895
-0.0010156400437190
-0.0010145521014040
-0.0010132717186368
-0.0010118020803526
-0.0010101463634152
-0.0010083077360086
-0.0010062893570296
-0.0010040943755024
-0.0010017259300502
-0.0009991871484322
-0.0009964811470567
-0.0009936110303955
-0.0009905798903310
-0.0009873908055011
-0.0009840468407188
-0.0009805510465041
-0.0009769064586298
-0.0009731160976364
-0.0009691829683555
-0.0009651100594675
-0.0009609003431416
-0.0009565567747189
-0.0009520822923014
-0.0009474798162402
-0.0009427522486004
-0.0009379024726711
-0.0009329333526135
-0.0009278477331904
-0.0009226484394503
-0.0009173382763957
-0.0009119200286780
-0.0009063964603578
-0.0009007703147657
-0.0008950443143204
-0.0008892211601919
-0.0008833035318984
-0.0008772940869037
-0.0008711954603204
-0.0008650102647598
-0.0008587410901556
-0.0008523905035125
-0.0008459610486656
-0.0008394552460773
-0.0008328755927555
-0.0008262245622307
-0.0008195046043751
-0.0008127181450932
-0.0008058675859960
-0.0007989553041366
-0.0007919836519408
-0.0007849549572114
-0.0007778715230171
-0.0007707356275505
-0.0007635495240171
-0.0007563154406151
-0.0007490355806711
-0.0007417121226855
-0.0007343472201582
-0.0007269430013456
-0.0007195015690279
-0.0007120250004374
-0.0007045153473781
-0.0006969746362466
-0.0006894048679234
-0.0006818080176804
-0.0006741860351369
-0.0006665408444112
-0.0006588743443388
-0.0006511884084350
-0.0006434848846966
-0.0006357655953954
-0.0006280323369711
-0.0006202868802116
-0.0006125309704740
-0.0006047663276860
-0.0005969946463031
-0.0005892175953003
-0.0005814368183203
-0.0005736539340591
-0.0005658705364739
-0.0005580881946718
-0.0005503084527358
-0.0005425328295760
-0.0005347628190536
-0.0005269998903537
-0.0005192454881232
-0.0005115010324070
-0.0005037679186046
-0.0004960475175140
-0.0004883411757119
-0.0004806502159950
-0.0004729759373930
-0.0004653196149764
-0.0004576824996682
-0.0004500658182443
-0.0004424707737900
-0.0004348985461094
-0.0004273502917291
-0.0004198271438417
-0.0004123302122973
-0.0004048605839063
-0.0003974193231312
-0.0003900074724016
-0.0003826260519393
-0.0003752760595242
-0.0003679584703321
-0.0003606742373013
-0.0003534242918339
-0.0003462095439608
-0.0003390308821672
-0.0003318891732502
-0.0003247852623738
-0.0003177199738131
-0.0003106941116982
-0.0003037084599261
-0.0002967637817852
-0.0002898608196003
-0.0002830002948339
-0.0002761829090777
-0.0002694093446998
-0.0002626802646144
-0.0002559963119555
-0.0002493581098391
-0.0002427662619782
-0.0002362213541067
-0.0002297239543553
-0.0002232746126323
-0.0002168738599367
-0.0002105222079275
-0.0002042201500703
-0.0001979681633288
-0.0001917667080504
-0.0001856162270201
-0.0001795171444721
-0.0001734698660271
-0.0001674747813808
-0.0001615322662895
-0.0001556426813153
-0.0001498063696680
-0.0001440236544332
-0.0001382948407653
-0.0001326202242674
-0.0001270000900390
-0.0001214347016357
-0.0001159243001113
-0.0001104691157684
-0.0001050693719242
-0.0000997252764940
-0.0000944370183875
-0.0000892047708768
-0.0000840286948231
-0.0000789089403806
-0.0000738456451225
-0.0000688389311300
-0.0000638889054675
-0.0000589956621702
-0.0000541592838804
-0.0000493798424011
-0.0000446573971160
-0.0000399919938207
-0.0000353836655970
-0.0000308324340217
-0.0000263383100914
-0.0000219012940881
-0.0000175213742440
-0.0000131985264576
-0.0000089327153216
-0.0000047238951850
-0.0000005720109400
0.0000035230022937
0.0000075612200904
0.0000115427285456
0.0000154676234606
0.0000193360096516
0.0000231480006199
0.0000269037191942
0.0000306032981455
0.0000342468797044
0.0000378346147459
0.0000413666620748
0.0000448431882054
0.0000482643679758
0.0000516303848159
0.0000549414302280
0.0000581977032263
0.0000613994099059
0.0000645467635868
0.0000676399854312
0.0000706793043762
0.0000736649564600
0.0000765971841565
0.0000794762358838
0.0000823023661910
0.0000850758361809
0.0000877969132722
0.0000904658706971
0.0000930829870917
0.0000956485463481
0.0000981628380583
0.0001006261577918
0.0001030388066727
0.0001054010908040
0.0001077133207575
0.0001099758114511
0.0001121888825514
0.0001143528585549
0.0001164680684033
0.0001185348451195
0.0001205535255440
0.0001225244505069
0.0001244479652361
0.0001263244192010
0.0001281541655779
0.0001299375607338
0.0001316749638670
0.0001333667371736
0.0001350132461029
0.0001366148591255
0.0001381719473788
0.0001396848843901
0.0001411540460330
0.0001425798109058
0.0001439625604775
0.0001453026787093
0.0001466005516002
0.0001478565667859
0.0001490711134885
0.0001502445828370
0.0001513773678791
0.0001524698632838
0.0001535224650918
0.0001545355705549
0.0001555095783437
0.0001564448888576
0.0001573419040330
0.0001582010268962
0.0001590226611368
0.0001598072108387
0.0001605550806540
0.0001612666759799
0.0001619424027483
0.0001625826671712
0.0001631878755543
0.0001637584343315
0.0001642947504178
0.0001647972312837
0.0001652662846156
0.0001657023179411
0.0001661057383066
0.0001664769522874
0.0001668163662699
0.0001671243864318
0.0001674014185163
0.0001676478676646
0.0001678641383338
0.0001680506345405
0.0001682077601112
0.0
