Support Forums › Forums › FIR Designer M Support › Saving / Loading Averaging Session Files. › Reply To: Saving / Loading Averaging Session Files.
5 August 2022 at 7:39 am
#527
Hi Bob,
The session file contains paths and filenames for all the measurement files used in the session. Usually this error message means the measurement files have been moved to a different folder/directory or deleted, and thus can’t be found. If that isn’t the case for you, send your .fda file to info at eclipseaudio dot com and we’ll take a look. Are you on windows or mac? Are the files on the same drive, a different drive or a network share?
