Support Forums › Forums › FIR Designer Support › Target curve design and export › Reply To: Target curve design and export
    4 September 2022 at 7:20 am #544
    >> there does not seem to be a way to copy and paste the filter prototypes used to design a
    >> target curve from the Mag sub-tab of the Target tab in workflow mode, to the Magnitude
    >> Design tab of the Direct Design mode
    That’s correct. The more common use case is the other way around; that is, design a target in direct design mode, save as a FDT file and import this on the main workflow Target tab.
    >> It would be nice if we can have the FIR Designer target file export in addition to the
    >> Export SMAART target file feature or an ability to copy filter prototypes between the two modes/tabs.
    Note.
