Support Forums › Forums › FIR Creator EX Support › Crown and Bss fir import › Reply To: Crown and Bss fir import
    2 November 2022 at 6:44 pm #583
    Hi Weiguo,
    >> Is there anyway to convert this response file using FIR Creator EX?
    No.
    >> I don’t know how to change it to 0 dB.
    You don’t need to have the measurement at around 0 dB. The “Import” tab has the gain adjustment for exactly this purpose.
    I have taken a look at your FDP file. Here are a few suggested minor adjustments:
    – On the “Mag Adjust” tab, change the gain of the “High Shelf” to -7.9 dB.
    – On the “Auto Mag” tab, change the “Min Freq” to 90 Hz.
    >> I imported a speaker response and created a fir file. But the result seems hardly doing anything.
    From what is shown on the “Export” tab, the FIR filter should definitely be audible.
    All I can suggest is checking that the processor is importing the file and that the filter is enabled. What processors are you using and what FIR filter format did you export?
