Support Forums › Forums › FIR Designer Support › Load FIR filter plus IIR Setup to PLM+ 12k44 from FIR Designer › Reply To: Load FIR filter plus IIR Setup to PLM+ 12k44 from FIR Designer
20 January 2023 at 10:39 pm
#610
Your project file has the FIR filter set for 96 kHz. The Lake FIR 3-way module only allows 48 kHz, 24 kHz and 12 kHz for module output channels.
Uncheck “FIR output sample rate.” This will change the FIR sample rate back to 48 kHz. (When we implemented “FIR output sample rate” as separate to the processing sample rate, we forgot to add an error message for Lake.)
