Support Forums › Forums › FIR Designer Support › Load FIR filter plus IIR Setup to PLM+ 12k44 from FIR Designer › Reply To: Load FIR filter plus IIR Setup to PLM+ 12k44 from FIR Designer
21 January 2023 at 8:59 am
#616
BTW If you only wish to use 1 output channel, you still need to set the other 2 output channels and the input channel. These other channels can be set with no enabled IIR filters and just am impulse FIR filter, but they do need to be set with something for the module to work.
Again, our apologies that this is not documented clearly.
