Support Forums › Forums › FIR Designer M Support › Trouble after 4.0.4 update › Reply To: Trouble after 4.0.4 update
    4 August 2023 at 1:29 pm #678
    >> I had 2.6.11 installed and I did an update install on top of that.
    >> Can I remove this install and reinstall 4.0.4?
    You can reinstall 2.6.11 and it will replace 4.0.4.
    However, we’ve just released 4.0.5 which should address the problem you’ve described. Unfortunately changes in then underlying GUI toolkit – not our code – caused a long list of problems with the UI, including tabs missing and menu problems.
    Let us know if 4.0.5 is working.
