Support Forums › Forums › FIR Creator EX Support › FIR for Subwoofers › Reply To: FIR for Subwoofers
23 August 2023 at 8:01 am
#690
The final length depends on your measurement and exactly what filtering is needed to achieve your goals. Just try it in FIR Creator EX. On the Export tab you can adjust the filter length and delay to where the filter is working the way you want, and you can see the result applied to your loudspeaker measurement. If you’re unsure how to use the workflow, take a look at the videos and tutorials on https://eclipseaudio.com/fir-filter-design-tutorial/.
