Support Forums › Forums › FIR Creator EX Support › FIR Filter Files › Reply To: FIR Filter Files
The data across the formats is effectively identical, with some caveats for WAV.
CSV(row) has FIR coefficients formatted as text in a row.
0.0010, -0.07, 1.0, 0.03 …..
CSV(column) has FIR coefficients formatted as text in a column
0.0010,
-0.07,
1.0,
0.03
WAV uses 24 bit WAV files to store the coefficients. WAV does quantize the data to 24 bit depth, but still has an effective range of > 130 dB. WAV also clips coefficients that are > 1.0 or < -1.0. But “FIR Creator EX” will give a warning if your FIR filter coefficients are outside -1.0 to 1.0 and you are trying to save as WAV.
I’d recommend using one of the CSV formats.
