Support Forums › Forums › FIR Designer Support › Reading FIR Coefficients from a piece of equipment in FIR Designer › Reply To: Reading FIR Coefficients from a piece of equipment in FIR Designer
    7 November 2023 at 1:37 pm #727
    What DSP is this? The file looks like a format we can implement to export from our products.
    Here’s a workflow to get to the FIR data.
    1. Copy the c0= ….. c383=”-1.497382E-07″ stuff to a text editor and use find/replace to remove all the ”
    2. Copy the c0= ….. c383=-1.497382E-07 from the text editor into an empty worksheet in Excel
    3. In Excel, select “Data” “Text to Columns” and use a space ” ” delimiter to break the single cell into 384 cells in a row.
    4. Copy the 384 cells
    5. On a vacant cell in Excel, right-click and select “Paste Special” “Transpose”. You’ll now have a column starting with c0=1.729377E-10 in the top cell.
    6. Select the 384 cells (in the column) and select “Data” “Text to Columns” with an equals sign = as a delimiter. Now you have two columns; one starting with c0 and one with 1.73e-10.
    7. Select all the number cells, right-click and select “Format” “Scientific” with 6 decimal places.
    8. Copy the 384 cells back to a text editor and save as a TXT file. The results follow below.
    9. Start “FIR Designer” and don’t load anything on the Import tab. On the Target tab and File sub-tab, press Load to load the TXT file. Uncheck Magnitude only and Phase only. Press “Find Peak”.
    10. In “FIR Designer”, on the Target tab and Curve sub-tab, uncheck “Use”.
    Now you have the filter loaded as a target and you can use the rest of the FIR Designer workflow to make a new FIR filter that either matches the loaded filter, or is slightly different to the loaded filter.
    1.729377E-10
    1.660994E-09
    4.847680E-09
    9.824653E-09
    1.651504E-08
    2.464442E-08
    3.372249E-08
    4.303874E-08
    5.167486E-08
    5.853556E-08
    6.239859E-08
    6.198304E-08
    5.603370E-08
    4.341751E-08
    2.322641E-08
    -5.120034E-09
    -4.178048E-08
    -8.641439E-08
    -1.381300E-07
    -1.954655E-07
    -2.568051E-07
    -3.229259E-07
    -3.937446E-07
    -4.687301E-07
    -5.471915E-07
    -6.282649E-07
    -7.109016E-07
    -7.938577E-07
    -8.756854E-07
    -9.547267E-07
    -1.029110E-06
    -1.096749E-06
    -1.155347E-06
    -1.202407E-06
    -1.235240E-06
    -1.250986E-06
    -1.246640E-06
    -1.219079E-06
    -1.165105E-06
    -1.081484E-06
    -9.650053E-07
    -8.125394E-07
    -6.211086E-07
    -3.879649E-07
    -1.106760E-07
    2.127800E-07
    5.839134E-07
    1.003613E-06
    1.472033E-06
    1.988471E-06
    2.551245E-06
    3.157569E-06
    3.803425E-06
    4.483443E-06
    5.190777E-06
    5.917002E-06
    6.652004E-06
    7.383904E-06
    8.098985E-06
    8.781649E-06
    9.414400E-06
    9.977855E-06
    1.045080E-05
    1.081027E-05
    1.103169E-05
    1.108909E-05
    1.095529E-05
    1.060225E-05
    1.000144E-05
    9.124249E-06
    7.942488E-06
    6.429002E-06
    4.558293E-06
    2.307259E-06
    -3.440127E-07
    -3.411375E-06
    -6.905689E-06
    -1.083183E-05
    -1.518766E-05
    -1.996291E-05
    -2.513814E-05
    -3.068354E-05
    -3.655791E-05
    -4.270750E-05
    -4.906507E-05
    -5.554887E-05
    -6.206189E-05
    -6.849110E-05
    -7.470701E-05
    -8.056335E-05
    -8.589702E-05
    -9.052844E-05
    -9.426207E-05
    -9.688744E-05
    -9.818060E-05
    -9.790600E-05
    -9.581886E-05
    -9.166820E-05
    -8.520030E-05
    -7.616292E-05
    -6.431005E-05
    -4.940737E-05
    -3.123833E-05
    -9.610889E-06
    1.563509E-05
    4.461989E-05
    7.741540E-05
    1.140361E-04
    1.544297E-04
    1.984674E-04
    2.459341E-04
    2.965184E-04
    3.498029E-04
    4.052553E-04
    4.622189E-04
    5.199053E-04
    5.773876E-04
    6.335947E-04
    6.873080E-04
    7.371600E-04
    7.816349E-04
    8.190728E-04
    8.476764E-04
    8.655218E-04
    8.705730E-04
    8.607008E-04
    8.337065E-04
    7.873506E-04
    7.193865E-04
    6.276002E-04
    5.098553E-04
    3.641445E-04
    1.886456E-04
    -1.821569E-05
    -2.576976E-04
    -5.306696E-04
    -8.375344E-04
    -1.178147E-03
    -1.551729E-03
    -1.956783E-03
    -2.391004E-03
    -2.851193E-03
    -3.333173E-03
    -3.831706E-03
    -4.340424E-03
    -4.851757E-03
    -5.356885E-03
    -5.845693E-03
    -6.306751E-03
    -6.727309E-03
    -7.093319E-03
    -7.389478E-03
    -7.599311E-03
    -7.705277E-03
    -7.688916E-03
    -7.531039E-03
    -7.211959E-03
    -6.711760E-03
    -6.010632E-03
    -5.089236E-03
    -3.929133E-03
    -2.513260E-03
    -8.264549E-04
    1.143962E-03
    3.407568E-03
    5.970169E-03
    8.833094E-03
    1.199246E-02
    1.543840E-02
    1.915431E-02
    2.311606E-02
    2.729123E-02
    3.163840E-02
    3.610642E-02
    4.063381E-02
    4.514824E-02
    4.956610E-02
    5.379218E-02
    5.771958E-02
    6.122979E-02
    6.419293E-02
    6.646832E-02
    6.790531E-02
    6.834441E-02
    6.761873E-02
    6.555584E-02
    6.198002E-02
    5.671488E-02
    4.958647E-02
    4.042677E-02
    2.907772E-02
    1.539563E-02
    -7.439497E-04
    -1.944087E-02
    -4.076468E-02
    -6.474858E-02
    -9.138297E-02
    -1.206089E-01
    -1.523110E-01
    -1.863112E-01
    8.843743E-01
    -2.892206E-01
    -6.599208E-03
    3.615452E-02
    1.598242E-02
    1.731194E-02
    1.387795E-02
    3.999668E-03
    -3.044116E-03
    -6.728054E-03
    -8.664512E-03
    -9.228375E-03
    -8.732223E-03
    -7.640320E-03
    -6.266622E-03
    -4.784203E-03
    -3.306211E-03
    -1.905310E-03
    -6.233517E-04
    5.149268E-04
    1.494201E-03
    2.305812E-03
    2.946428E-03
    3.417318E-03
    3.724015E-03
    3.875991E-03
    3.886183E-03
    3.770392E-03
    3.546575E-03
    3.234104E-03
    2.853011E-03
    2.423287E-03
    1.964241E-03
    1.493954E-03
    1.028830E-03
    5.832554E-04
    1.693617E-04
    -2.031128E-04
    -5.268657E-04
    -7.969904E-04
    -1.010863E-03
    -1.167967E-03
    -1.269674E-03
    -1.318984E-03
    -1.320242E-03
    -1.278850E-03
    -1.200972E-03
    -1.093246E-03
    -9.625225E-04
    -8.156139E-04
    -6.590835E-04
    -4.990608E-04
    -3.410935E-04
    -1.900346E-04
    -4.996548E-05
    7.584885E-05
    1.849720E-04
    2.757810E-04
    3.474262E-04
    3.997714E-04
    4.333170E-04
    4.491120E-04
    4.486584E-04
    4.338109E-04
    4.066777E-04
    3.695239E-04
    3.246806E-04
    2.744624E-04
    2.210949E-04
    1.666531E-04
    1.130114E-04
    6.180637E-05
    1.441058E-05
    -2.808139E-05
    -6.485680E-05
    -9.537906E-05
    -1.193736E-04
    -1.368073E-04
    -1.478618E-04
    -1.529037E-04
    -1.524516E-04
    -1.471423E-04
    -1.376968E-04
    -1.248878E-04
    -1.095084E-04
    -9.234507E-05
    -7.415237E-05
    -5.563263E-05
    -3.741916E-05
    -2.006370E-05
    -4.027839E-06
    1.032156E-05
    2.271350E-05
    3.297070E-05
    4.100468E-05
    4.680857E-05
    5.044806E-05
    5.205111E-05
    5.179674E-05
    4.990351E-05
    4.661797E-05
    4.220361E-05
    3.693038E-05
    3.106534E-05
    2.486435E-05
    1.856510E-05
    1.238155E-05
    6.499670E-06
    1.074675E-06
    -3.770514E-06
    -7.945564E-06
    -1.139195E-05
    -1.408123E-05
    -1.601258E-05
    -1.720964E-05
    -1.771704E-05
    -1.759654E-05
    -1.692314E-05
    -1.578115E-05
    -1.426039E-05
    -1.245273E-05
    -1.044886E-05
    -8.335524E-06
    -6.193159E-06
    -4.094028E-06
    -2.100820E-06
    -2.657143E-07
    1.370112E-06
    2.776560E-06
    3.934326E-06
    4.834297E-06
    5.476695E-06
    5.870007E-06
    6.029782E-06
    5.977322E-06
    5.738356E-06
    5.341698E-06
    4.817980E-06
    4.198453E-06
    3.513915E-06
    2.793769E-06
    2.065233E-06
    1.352714E-06
    6.773380E-07
    5.664420E-08
    -4.955768E-07
    -9.693001E-07
    -1.358164E-06
    -1.659259E-06
    -1.872831E-06
    -2.001917E-06
    -2.051928E-06
    -2.030210E-06
    -1.945586E-06
    -1.807905E-06
    -1.627609E-06
    -1.415329E-06
    -1.181522E-06
    -9.361540E-07
    -6.884342E-07
    -4.466046E-07
    -2.177844E-07
    -7.867240E-09
    1.785291E-07
    3.380671E-07
    4.686520E-07
    5.693586E-07
    6.403283E-07
    6.826440E-07
    6.981886E-07
    6.894933E-07
    6.595836E-07
    6.118250E-07
    5.497766E-07
    4.770547E-07
    3.972093E-07
    3.136181E-07
    2.293966E-07
    1.473278E-07
    6.981025E-08
    -1.173890E-09
    -6.319897E-08
    -1.133212E-07
    -1.497382E-07
