Support Forums Forums FIR Creator EX Support Dynacord/Electro Voice / multirate sampling FIR Filter Reply To: Dynacord/Electro Voice / multirate sampling FIR Filter
    8 November 2023 at 7:08 pm #730
    Thank you for your fast answer.
    A little bit of background:
    I want to build up a three way system with FIR Filters. So i want to use:
    – 48khz Fitlers for the Tweeter (Frequencyrange: 10-20khz, resolution with 512 Tabs: 93,75Hz)
    – 24khz Filters for Midrange (800-10000Hz, resolution: 46,875 Hz)
    – 12Khz Filters for Low-Mid (80-800Hz, resolution: 23,4375Hz)
    i guess you already knew that, but i just wanted to make it clear.
    So, if:
    “Note: IRIS-Net appears to load both 48 kHz and 96 kHz FIR filter files, and convert them appropriately to the sample rate of the processor.”
    What would happen to my resolution from the 12 khz Filter, when it is converted to 48khz again?
    • This reply was modified 2 years, 4 months ago by MSchueller.
