Support Forums › Forums › SpeakerMeasure Support › Bug 1.0.5 › Reply To: Bug 1.0.5
24 August 2024 at 1:02 pm
#901
Sorry to hear this. This is first crash report we’ve had in a while.
Re 1.
– What ASIO buffer size are you using? I suggest something larger than 512 samples at 48 kHz.
– Can you try a different audio interface? We’ve done most testing with RME interfaces and their drivers are very stable and well maintained. We’ve also used MOTU and a few others.
Re 2. Can you record a video clearly showing the UI prior to and as it crashes? There may be clues in exactly what stage the UI is at before the crash.
Re 3. I can’t explain this but it’s likely related to the audio interface issues.
