Support Forums › Forums › FIR Designer Support › FIR designer can’t ajust total error range › Reply To: FIR designer can’t ajust total error range
    11 October 2024 at 5:27 am #925
    I just tested it here again and it appears to be working. The “Range” controls the calculation that updates the “Magnitude: max…” and “Phase: max.. ” numbers, directly below the “Range”. It doesn’t update the plot display. Since the error mostly occurs at low frequencies, if you increase the range low freq. number, the error numbers should reduce to close to 0 dB and 0 deg. Can you confirm this?
