Support Forums › Forums › FIR Designer Support › FIR designer can’t ajust total error range › Reply To: FIR designer can’t ajust total error range
11 October 2024 at 6:28 am
#926
When you start to type or highlight the #, it immediately resets back to 10Hz.You can’t type anything. Tested it on a colleague’s computer and it worked a couple times, then started acting the same way.
