Support Forums › Forums › FIR Designer M Support › Import of drivers measurment files › Reply To: Import of drivers measurment files
Hello, I tried to make LR2 linear phase from your sample file(System2 3way LF MF brickwall) you send me before. But unfortunately magnitude and phase is not very flat as you can see in the screen shot attached. Can you help me to see what I’m doing wrong?
Attached I’m sending project file.
Best Regards!
We’ll send a modified file back to you. Open your original file and the new file in separate FIR Designer M windows and study the differences. The primary difference is that you had all the “FIR Auto Mag” tabs set to minimum phase, not linear phase. We made some other adjustments on various tabs also.
