Support Forums Forums FIR Designer M Support Asymetrical Filters
    • 17 February 2025 at 1:14 am #994
      Hello Dear Eclipse Audio,
      From yesterday I am trying to make FIR for Line Array that lower crossover is problem. Maybe the right way to fix the dispersion of my box is to use Asymmetrical filters.
      I found HPF – KH2 and LPF – KH2. I can`t find a solution to make them Mirrored. The LF driver need to be higher order (similar to 6th order LR) and HF compression driver to going lower frequency with gradual roll off level.
      Here is the picture KH2 Filter
      I need to make this filter “inverted” HPF filter to looks like LPF and LPF looks like HPF.
      The reason I want to use this filters is the perfect summing.
      Can you help me? Please.
      Ivan Tsanov
      • This topic was modified 1 year ago by Hilevel.
