Support Forums Forums FIR Designer Support Error respons diagram
    • 16 May 2020 at 7:22 pm #149
      Hello EA.
      Regarding shown errors in the diagram at export tab.
      Can they be ignord if errors are outside the working range?
      Eg a HF driver used in the range 1kHz-20kHz with HPF set at 1 kHz with for example 24dB/oct slope. Significant errors will occur around 500Hz and below for souch driver then.
      • This topic was modified 5 years, 8 months ago by Thomas.
