    • 16 October 2025 at 2:45 am #501157
      Hi there,
      found some strange behavior when using FIR export by the multi channel export function => “Save FIR’s”.
      I’m using a 6-channel convolution engine in ROON. Channels 1, 2 and 3 are mains channels, channels 4, 5, 6 are woofers. With 44,1 kHz multi channel export ONLY, export did a wrong channel mapping. Always channel No. 1 had the content of one of the woofer FIR filters. Neither with 48 kHz and above, nor in manual/single export with the single channel export.
      I checked countless times if it was a mistake in the -cfg file in ROON or in my manual mapping procedure but it wasn’t.
      Is there any channel mismatch known with “multi-channel FIR export” before? Or what mistake did I do – any idea?
      Thanks, Olli.
