Support Forums Forums FIR Designer Support Show correction filter phase in the main graph window
    • 28 March 2021 at 5:40 am #323
      I think sometimes it is useful (especially for illustrative purposes) to be able to show the phase response of the correction filter in the main graphing window within the FIR: Phase Adjust tab. For instance, on the image below, I would like to see the phase response (the green curve in the upper graph display) of the chosen filter prototype graphed in the bottom graph display so I can see the original (purple), the filter prototype graph and the final phase graph (blue) on the same graph window. Obviously, this graph should be able to be toggled on/off like the others.
      • This topic was modified 4 years, 5 months ago by musan.
