Support Forums › Forums › FIR Designer Support › Wishlist › Reply To: Wishlist
Hi Eddi,
‘Phase only’ on import: We’ve added that to the todo list.
Two measurement paths – separate magnitude and phase: It’s unlikely we’ll implement this but you can achieve this in the following way.
– Create your measurement as a 3 column TXT or CSV file (freq Hz, mag dB, phase deg) with the mag and phase from your separate measurements
– Load this measurement on the Import tab
– Do all your desired magnitude manipulation on the Mag Adjust and Auto Mag tabs, and make sure ALL the filters are set to ‘Linear phase’
– Do all your desired phase adjustments on the Phase Adjust and Auto Phase tabs
The result at the Voicing tab is the combination of the above, and you can then voice to taste.
Keyboard keys for filter dB, Q and frequency: We’ll consider it.
Regarding the binaural measurements, are you request we add measurement capability into our software? We have considered this but many people are very particular about the measurement tools they use – Klippel, SMAART, SysTune, SoundCheck, REW, etc. – so to date, we haven’t ventured into this space.
Regarding the ‘AVG + phase from one ear’, it sounds like you would like an additional “Averaging Mode” called “Power (using Ref. phase)”. With this, the phase from the measurement denoted as the ‘Reference’ would be used. We’ll consider this.
