Support Forums › Forums › FIR Designer M Support › Moving mic technic › Reply To: Moving mic technic
    17 June 2025 at 11:26 am #1073
    Take a look at sections 5 and 7 of
    FIR Filter Guide
    I always set Filter-Delay to 0 in FIR Designer ….. This is to slightly increase the resolution of the low frequency control within the limited number of filter taps.
    The overall filter length is what mostly affects the low frequency resolution and control. The delay setting mostly relates to the type of filter you are making. With a delay of 0, you’re making a minimum-phase filter, which you could also do with IIR filters, or a mix of both IIR and FIR.
