Support Forums › Forums › FIR Designer Support › FIR Designer and Hypex › Reply To: FIR Designer and Hypex
19 June 2025 at 4:27 pm
#1075
What is the effect of running a 96kHz filter on the 93675 hZ DSP of Hypex? Will it work with a slight frequency offset in the magnitude response?
93.75 kHz is 97.66% of 96 kHz. So the net effect of running a 96 kHz designed filter at 93.75 kHz is that the effective frequency response will be 2.34% lower in frequency. (For example a response peak designed for 18 kHz will actually be at 17.59 kHz.)
