Support Forums › Forums › FIR Designer M Support › Transfer Function Export › Reply To: Transfer Function Export
    14 May 2020 at 5:22 pm #147
    Hi!
    Thank you very much for taking this into consideration. 1/96th octave resolution is more than enough for most applications. Even if this would be the only resolution possible in the beginning, it would be great as the data can be resampled externally.
    Thank you very much!
