Support Forums › Forums › FIR Designer M Support › 2-Way Crossover Design › Reply To: 2-Way Crossover Design
    25 May 2020 at 12:53 pm #157
    Hi daemlacken,
    We mostly answer direct product questions but here are few things to try.
    Regarding the measurements at different distances. You could design the filtering with the measurements you have then verify/adjust the relative driver levels later with measurements at a common distance outside (where there are no walls). Or take some new, gated measurements outside. I’d also suggest talking some off-axis measurements to help choose a crossover point where the drivers beam-width’s are roughly similar. Floyd Toole has published on the topic of subjective preference for loudspeakers with well-controlled directivity that varies smoothly over frequency.
