Support Forums › Forums › FIR Designer Support › FIR Filter Design for Loudspeaker Equalization – FAQ › Reply To: FIR Filter Design for Loudspeaker Equalization – FAQ
    14 July 2020 at 10:38 pm #223
    >> Is it correct to assume that this loudspeaker is displaying non-minimum phase behavior
    >> around the crossover region when one looks at the 2-nd order all-pass response of its
    >> phase response?
    Yes.
    >> Can the phase adjustments being done around the crossover region, to flatten the phase
    >> response, be deemed to be “maximum phase” corrections seeing that we are inverting an
    >> all-pass response?
    Yes. But remember this is just one loudspeaker. Each loudspeaker is different.
    >> Is the flattening of both the magnitude (EQ boosting) and phase response around the
    >> crossover region not going to introduce audible artifacts like pre-ringing?
    Maybe. Linear-phase brick-wall crossovers also have pre-ringing but it’s rare that people say they think they can hear it.
    >> Can the same EQ concepts be readily applied in correcting the room transfer function
    >> displaying non-minimum phase characteristics at the listening/measurement position?
    Yes but I’d suggest doing a literature search on the topics of room impulse response correction and inverting room impulse responses; maybe in the Audio Engineering Society resource library.
