Support Forums › Forums › FIR Designer Support › WAV file measurements from REW › Reply To: WAV file measurements from REW
30 November 2020 at 9:02 pm
#290
WAV file import problems are common from REW since the IR peak is often well into the WAV file, rather than near the start. Better to use the IR TXT export. See REW on https://eclipseaudio.com/loudspeaker-measurements/
