Helo,
I am using ALL active XO in XTA, 2 ways speaker, one driver in each output. So woofer and tweeter is in different output. I have no problem with the tweeter as it is easier and I can move it around with all pass filter but the woofer’s phase is difficult to get it at 0 and flat!
Can you answer question 1? Do I need enable IIR HPF at 100hz? Do i need to turn on all eq before measurement? Or do i need to open all filter and only keep the eq?
Also the measurement was taken from average of 6 measurements around my head in the seating position.
These questions have a lot to do with FIR, such as 300hz overshoot and question 3. Please answer them.
Thank you.
