3 December 2021 at 6:21 am
#375
No you don’t need to remeasure. (The sample rate of the measurement does not need to match the FIR Designer sample rate.) Just change the sample rate in FIR Designer to 96 kHz and take a look at the Export tab – you’ll probably need to double the filter delay and length settings to match the time intervals at 48 kHz – then export the filter again.
