Support Forums › Forums › FIR Designer M Support › Suggestion: Global automag/-phase disable › Reply To: Suggestion: Global automag/-phase disable
12 January 2022 at 11:15 am
#397
Hi Lukas,
To the right of “Auto Mag Correction” and “Auto Phase Correction” there are “Enable” checkboxes. Unchecking these will save you having to turn off each individual frequency band, however these enable checkboxes are per-channel, and would need to be toggled for each channel.
We understand what you are describing w.r.t. performance, especially if you are using mouse control of filters (which triggers continual updating of everything). We’ll consider a global enable/disable idea. Thanks.
Shortcuts, also a great idea. We’ll look into it.
