26 October 2025 at 3:21 am
#501166
Hi Tohimir,
The Auto Mag problem you are seeing is because the channel target responses are flat; each channel has a crossover filter set on the Mag Adjust tab but the Auto Mag is trying to push the channel back to flat. If you set crossover filters on the channel targets, the Auto Mag will then push each channel towards the intended crossover target response.
I have sent you an updated FDS file. Please study how every tab is set. The settings are not the only way to set up a 2-way, but they show you what is possible. These methods are in the videos and tutorials available on our website.
