    5 November 2025 at 12:40 pm #501170
    It’s most likely caused by the FIR Designer channel sample rate not matching the sample rate of the miniDSP. For example, if the miniDSP runs at 48 kHz, but the FIR Designer channel is set to 96 kHz, then a crossover in the FIR filter will appear at half the frequency. Similarly if the miniDSP runs at 96 kHz and the FIR Designer channel is set to 48 kHz, then a crossover in the FIR filter appear at double the intended frequency.
