5 November 2025 at 8:21 pm
#501171
Hello, I found in the miniDSP Flex specifications that it operates at 96 kHz / 32-bit, while in FIR Designer it is set to 48 kHz (as shown in the Export tab).
According to your comment, if the miniDSP runs at 96 kHz and FIR Designer is set to 48 kHz, then the FIR filter will appear at double the intended frequency.
This is confusing to me as it seems opposite to me, because I have a 2 kHz crossover in FIR Designer, but it appears at 4 kHz on the miniDSP.
Best Regards!
Tihomir
