    6 November 2025 at 5:27 am #501172
    You said the miniDSP runs operates at 96 kHz and you have FIR Designer set to 48 kHz. When a filter is designed at a sample rate of 48 kHz (which you have set in FIR Designer), then actually run at 96 kHz (which the miniDSP operates at), the EQ response of the filter will appear at double frequency – which you confirmed in the statement “I have a 2 kHz crossover in FIR Designer, but it appears at 4 kHz on the miniDSP.”
    You need to change the FIR Designer channels to be 96 kHz, so that the exported filter sample rate matches the miniDSP.
